6/13/2021 1:12 PM | |
Joined: 9/21/2012 Last visit: 6/5/2024 Posts: 3961 Rating: (449) |
First you start PLCsim and load the project there, then you start the HMI simulator, and you can start working. |
6/13/2021 1:26 PM | |
Joined: 3/24/2018 Last visit: 5/5/2024 Posts: 236 Rating: (1) |
Hi, what about the procedure described in the previous link? |
6/13/2021 1:30 PM | |
did you look at the date of the document? It's not up-to-date anymore. |
6/13/2021 1:32 PM | |
I face this problem in the link No need to do this procedure What about advanced simulator? |
6/13/2021 1:34 PM | |
So what is your problem, and witch hardware and software? |
6/13/2021 1:40 PM | |
HI, We use simatic manager v5.6 professional our station consist of: CPU318-2DP connected to I/O module " PROFIBUS", Danfoss inverter and HMI "MPI" we not able to simulate PLC and HMI together without any error. No result "0" in the simulator table. although in the online mode every think run O.K |
6/13/2021 1:43 PM | |
If the HMI is connected via MPI, is your S7 Online connection method PLCsim.MPI.1? |
6/13/2021 1:44 PM | |
YES What about previous link is out of service now. what about advanced PLC Simulator? |
Last edited by: Pepsi Cola at: 06/13/2021 13:53:14Last edited by: Pepsi Cola at: 06/13/2021 13:54:53 |
6/13/2021 1:55 PM | |
If there is no communication between PLC and HMI, all numerical values show on the HMI are ####, do you experience that or are your values numbers? It really hard to play the guessing game, since you are not providing us with screen shots. |
