7/26/2018 7:18 PM | |
Posts: 2 Rating: (0) |
if i dont have boot file in usb stick which is with the ipc477d any other way to boot the ipc ? is there any download link for the ipc required all files ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 7/27/2018 6:28:08 AMNew subject after splitting |
7/27/2018 6:27 AM | |
suggest me how to boot my ipc if i dont have boot file in usb stick which is with the ipc . |
7/27/2018 8:26 AM | |
Joined: 10/18/2012 Last visit: 10/21/2024 Posts: 225 Rating: (23) |
Hello VINOD KUMAR, you can boot your IPC from USB stick with FreeDOS. Instructions to do that are here: You may also look at the IPC477D Manual - chapter 4 "Commissioning the device". Is that, what you want? regards, |
