1/25/2019 4:38 PM | |
Joined: 12/12/2016 Last visit: 4/8/2024 Posts: 640 Rating:
Hello IOT2000 community! Because this question was asked various times here on the forum we decided to make a topic on how to build your own IOT2000 image. You can find the detailed instructions in the attachment. Kind regards! AttachmentCreateImageIOT2000_en.pdf (2648 Downloads) |
6 thankful Users |
7/17/2019 1:34 PM | |
Hello IOT2000 Community! Looking to create a customized IOT2000 image? We now have a simplified (dockerized) tutorial. Check out the files in the attachment and please give us feedback. Kind regards! Attachmentcustom-image.zip (1596 Downloads) |
7 thankful Users |
12/15/2019 5:03 PM | |
Posts: 1 Rating:
Fe_lipe, Thank you for posting this. I am following the dockerized method to create the custom image, and I have a couple of things I am not sure about:
I am using the iot2000 in many projects, and it takes a while to set it up the same way everytime, so I am trying to have an image very similar to the released V2.4.0 just with node-red mindconnect and MODBUS nodes already installed. Thank you Fe_lipe! Best regards, Nael |
1/14/2020 3:30 PM | |
Hello, Just noticed there is also an issue for this on here! So indeed using a 32 Bit System is not possible and currently not mentioned in the documentation. Thanks for the hint. |
2/19/2020 8:42 AM | |
Joined: 8/7/2018 Last visit: 2/27/2024 Posts: 31 Rating:
Thanks dear for your post |
Experience with the process, Steel Making, and logistic systems. |
