6/29/2017 9:34 AM | |
Posts: 5 Rating: (0) |
Hi Mr.DevGuy I have trying to use the modbus serial node in iot2040, i am using the 2.1.3 image version.I have configured the node when i am deploying the flow, it returns "illegal instruction" and the node-red stops. Could you detail me how you have communicated with the Modbus serial node. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 6/30/2017 10:21:19 AMNew subject after splitting |
6/30/2017 10:24 AM | |
Posts: 215 Rating: (6) |
Can you show us your configuration? Mark the node, export it and copy the text here. |
7/1/2017 12:59 PM | |
Hi JDarlua I have uploaded the flow i have used. kindly suggest me a solution. AttachmentFlow1.txt (578 Downloads) |
11/20/2017 9:14 AM | |
Posts: 12 Rating: (0) |
i have the same issue. please help me to get out of it. I amusing Node-RED version: v0.17.5 Node.js version: v6.9.2 |
