5/4/2012 1:45 PM | |
Posts: 3609 Rating: (29) |
Import of a technical question of banoe81
5/4/2012 4:26 PM | |
Joined: 9/27/2006 Last visit: 4/28/2024 Posts: 12257 Rating: (2665) |
Hello banoe; In the following links you should have everything you need to connect a Diris A40 Profibus-DP slave to a Profibus-DP master' such as a CPu 31x-2DP: Diris A40 datasheet: http://www.sca.co.rs/Download/Socomec_DIRIS%20A40.pdf Diris A40 Profibus module manualand Gsd file (downloads): http://www.socomec.com/documentation-diris-a40_en.html |
5/5/2012 4:10 AM | |
Joined: 9/2/2009 Last visit: 4/2/2024 Posts: 11 Rating: (0) |
Dear Daniel, Thanks for your information. Regards |
5/8/2012 1:36 AM | |
Dear Daniel Thanks for your repply, you can see my attachment for HWconfig,but i still confuse about configuration module #1 "main Measurement" is that same with "Principal Value" module? as you can see at my attachment at right side catalog and "Supplementary measurement " same with " Other Value" module #2? Thanks. Regards Banoe81 AttachmentA40.pdf (1107 Downloads) |
4/2/2014 12:35 PM | |
Joined: 9/1/2005 Last visit: 3/5/2024 Posts: 4097 Rating: (193) |
follow up question published by Tormis split to a seperate thread with the subject How To communication between Diris A40 to S7-300 using universal module. Best regards CS Moderator |
