12/10/2022 4:38 PM | |
Joined: 9/27/2006 Last visit: 9/8/2024 Posts: 12282 Rating: (2682) |
Hello GTSAGarcia; The following article describes the MP panels as OPC XML servers (with variants using XML as a gateway or direct ) and provides a WinCC Flexible sample project as a guide: https://support.industry.siemens.com/cs/ca/en/view/22701694 Hope this helps, Daniel Chartier |
12/13/2022 3:48 PM | |
Joined: 4/8/2021 Last visit: 8/6/2024 Posts: 638 Rating: (103) |
Hi Garcia, I think you don't need an aditional Runtime in order to save the file in a shared network drive. It can be done directly from the panel. Have a look at following links, seems that is decribed how to do it. https://support.industry.siemens.com/cs/ww/en/view/13336639 https://support.industry.siemens.com/cs/ww/en/view/92346478 Hope it helps. |
Best regards, |
