10/23/2020 7:56 PM | |||
Joined: 12/28/2016 Last visit: 8/28/2024 Posts: 434 Rating:
Hi vorapob Please check this page Getting Started S7 Project for SIWAREX U (Step 7 Classic and TIA-PortalThis project shows an example of how a SIWAREX U can be integrated into a S7 system. The integration is realised with different slave modules. It contains a S7 program with integration of SIWAREX U and message function. It contains also a WinCC flexible project with visualisation ... Description: DownloadsGetting started S7 project for SIWAREX FTC for belt scale
Last edited by: Madadi at: 10/23/2020 20:00:16Last edited by: Madadi at: 10/23/2020 20:22:00Last edited by: Jen_Moderator at: 10/26/2020 08:56:52Optimized links. https://pnap.ir |
10/26/2020 10:51 AM | |
Joined: 1/4/2007 Last visit: 9/2/2024 Posts: 1142 Rating:
Hello vorapob, On the internet, you can find some S7 example projects. The link was already mentioned from Madadi. There exist S7 example projects for S7-300/400 and S7-1500 PLCs. For S7-1200 PLC, there exist no S7 example project. (Maybe the S7 example project for S7-1500 PLC works for S7-1200, but I’m not sure.) Attached you can find some screenshots, how to do the calibration. Best regards Siwarexi
AttachmentCalibration_with_HMI-Panel.pdf (539 Downloads) |
