9/15/2023 12:13 AM | |
Joined: 5/21/2020 Last visit: 3/18/2024 Posts: 5 Rating:
I'm configuring an 828D CNC and I need to send an analog voltage signal to an inverter through the output of the PPU's X3 module. What I would like to know is how I carry out this configuration by collecting the speed of the CNC program through an S function and sending it to the analog output, I searched for some manuals, but I only found https://cache.industry.siemens.com/dl/files/477/90581477/att_110649/v1/828D_GH_en_en-US.pdf starting on page 207 and some others that basically say the same thing. I tried to perform the same configuration procedure on the PLC but it didn't work. Could anyone tell me how I carry out this configuration from collecting the value of S function to sending the value to the analog output? |
9/15/2023 1:13 PM | |
Joined: 5/24/2016 Last visit: 7/15/2024 Posts: 338 Rating:
Hello. Ah i see I have not had to read a S variable from the NC to the PLC, looking in the manual you should be able to use DB3700.DBB0004 Then you can use this manual to look into the programming of the PP78/48 SINUMERIK 828D PPU and components Best Regards Riddersholm |
9/15/2023 4:46 PM | |
So, I'm doing exactly what the manual you sent me asks and sending a value to the QW76 output, but I don't have the value in the analog output.
9/15/2023 6:03 PM | |
Hello. Interesting Please check IB50 and IB51 for diagnostic Best regards Riddersholm |
