6/14/2021 3:09 PM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating:
Hi, from your picture I assume you want to use the analog outputs of the sensor to communicate with the IOT? The most easy thing at the beginning is to display the values on the node-red dashboard. Therefore I try to give a step-by-step instruction:
Best regards! |
Last edited by: bergmanu at: 06/14/2021 15:10:05Not working for IOT2050 support anymore from March 1st, 2024. |
6/16/2021 10:17 AM | |
Posts: 6 Rating:
Hello, Thanks a lot, here I am attaching the node-red flow. Please find the text file. Thanks Attachmentflows.txt (1010 Downloads) |
6/17/2021 3:53 PM | |
Posts: 6 Rating:
Hello sir, Thanks for your reply, but the problem is the same. I am getting the same output and one thing is clear that this 140 or 143 value is a garbage value because I am getting this value without connecting the Sensor's pin. I am sending you the connections diagram with the sensor pin with the gateway pin. Please go through it and suggests me the correct pin connections with the same pin name which are given at the sensors and gateway. Please find the attachment. I am really sorry to annoy you but I am trying it and not getting the desired out put. AttachmentConnections.pdf (1029 Downloads) |
