12/10/2018 4:30 PM | |
Joined: 4/28/2015 Last visit: 4/30/2024 Posts: 3345 Rating: (377)
Hi, I have done this several times. It is normal that you can't see the filesystem in Windows. But if you choose the SD card within the Win32DiskImager it will copy the card bit by bit and it is not neccessary to have the card formatted to see the file system in Windows. Another possibility is to use HDD Raw Copy Tool. There you will have an image which is compressed. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
