5/11/2012 10:39 AM | |
Posts: 1547 Rating: (129)
Hello, OPC tag has to be defined in iFIX, there is no need to define it first in OPC Scout. You have to follow the specific Item definition of the SIMAITC NET OPC Server, but you have to do this in iFIX. The ItemID or Tagname or OPC-syntax is as follow: Protocol ID: Regular S7: For more details refer the OPC Manual at chapter 2.5.1. There you will find a detailed description about the right syntax. |
