8/20/2019 6:58 AM | |
Joined: 4/14/2017 Last visit: 8/2/2023 Posts: 32 Rating: (0) |
I am doing same work. can you pls guide me how to download the software setup "winpcin" ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/20/2019 11:02:42New subject after splitting |
8/21/2019 3:16 AM | |
Joined: 10/17/2007 Last visit: 7/14/2024 Posts: 4008 Rating: (353)
Please help me to understand your question. make clean the question---I suggest you make new title /new topic of post Such as--Topic --" How to use WinPCIN software to transfer back up data from and to SINUMERIK 810D" What do you want to do? Post picture of your machine system.
8/23/2019 9:27 AM | |
THANKS For the information about WINPCIN, but before purchasing software, I want to make sure about which software required exactly. I have following models or part no. pls also check pix. HMI: OP270 (6AV6 542-OCC10-0AX0) SINUMERIC 810D Secondly I am little bit confuse about Sinumeric(I am new on it), its a cotroller and I have already downloaded Its backup through simatic manager in it. Now where to download NC files? Either in sinumeric controller or in HMI?(i.e HMI and sinumeric should have their separate backups?) . Plz also suggest the software for HMI and WINPCIN will be use for transfer NC files? AttachmentPIX.zip (979 Downloads) |
8/24/2019 10:20 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (875)
OK, fine. NC data contains various machine related information e.g. general NC specific data, channel data, axis specific data, tool data & intialization files (INI) requires for operation of inetrnal softwares which is not included in machine PLC logic. This back up data is required to restore machine back into oepration in case if any data gets corrupt or lost due to battery failure or in case of replacement of data storage hardware items. Please check type of MMC or PCU installed on your machine & does it has RS232 port. If yes, check below points. You need WinPCIN software, PG/PC with RS232 port (USB to RS232 adaptor may help you) & communication cable. Please refer attached sheets, which expalin cable connection & step by step procedure for data back up & restore. (Courtesy - Siemens technical forum member) If your MMC does not support RS232, then you need to back up your NC data on PCMCIA card installed on NCU. HTH. AttachmentData_Loading_through_WINPCIN.pdf[1].pdf (1115 Downloads) |
