3/25/2023 9:01 PM | |
Joined: 9/27/2006 Last visit: 8/13/2024 Posts: 12277 Rating:
Hello ravi; You will find this inofrmation in the Step 7 cross-references, under Program structure. Selecting the dependency structure will show the blocks calling other blocks, including DBs. More information in the Programming with Step 7 manual, ch.14: https://support.industry.siemens.com/cs/ca/en/view/18652056 Hope this helps, Daniel Chartier |
2 thankful Users |
3/27/2023 6:22 AM | |
Joined: 7/22/2022 Last visit: 8/13/2024 Posts: 42 Rating:
Thanks alot .but i think , this is little tricky I wanted to find DB825, where else used in the same way as per screenshot Is there any keyword search which searches for in all the block . Default ctrl+F & Cross reference is not helping me It is very difficult to open and check each and every block as code is huge. Please help me
3/29/2023 1:39 AM | |
Joined: 9/21/2012 Last visit: 8/13/2024 Posts: 4094 Rating:
There is no cross reference for indirect addressing. |
4/2/2023 4:13 PM | |
Joined: 5/28/2008 Last visit: 8/6/2024 Posts: 4515 Rating:
Hello, Please tell us what is shown when you search for DB825 using cross reference? Indirect addressing is like you call a certain DB and then in every line in STL language you use DBW, DBB, DBD, ...etc. so, when you search for it, it will not appear in cross reference. |
Ayman Elotaify |
