5/12/2014 6:06 PM | |
Joined: 1/28/2009 Last visit: 10/26/2024 Posts: 6852 Rating: (1365) |
Hello, Short answers to your questions:
There is a big difference between blocks in a PLC and scripts in WINCC.The later is executed in a PC with different resources(perhaps higher level) while PLC codes should be concise and close to machine level(mostly). Best regards,Hamid Hosseini |
This contribution was helpful to4 thankful Users |
5/12/2014 9:35 PM | |
Posts: 5225 Rating: (1196) |
Hi. You can use a spreadsheet program to generate coding for your FC / DB / FB. What is true though is that the spreadsheet can not be saved directly to the code block. You need to use an import procedure or copy-paste. Where there is a structure that needs to be repeated, the text functions of a spreadsheet can be of much help. Magica, I am however unsure if this is what you had I mind. w |
5/13/2014 3:47 PM | |
Posts: 35 Rating: (0) |
Hello William, thanks very much for your answer. Yes,your mean what I want.But I didn't have such experience before. Is it possible for you to give me more details about how to generate the source code for my FC/DB using the spreadsheet in the EXCEL. Have you tried it before?can you give me an example. Thanks a lot in advance. |
5/13/2014 5:05 PM | |
Joined: 11/26/2011 Last visit: 6/29/2023 Posts: 508 Rating: (23) |
Hi, I can give you some example what i found on internet which is similar to this. You can modify or get a idea from this. Go through it. AttachmentSTL_Generator.zip (1749 Downloads) |
