11/3/2020 2:17 PM | |
Joined: 8/28/2019 Last visit: 6/13/2022 Posts: 18 Rating:
I'm having the same issue in TIA Portal v15.1. Any help is appreciated. Thanks in advance! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/04/2020 08:28:22New subject after splitting |
11/4/2020 6:06 PM | |
Joined: 7/7/2010 Last visit: 7/16/2024 Posts: 14954 Rating:
What is the reason you wish to export them? Options:
science guy |
11/4/2020 7:36 PM | |
Joined: 3/30/2020 Last visit: 7/12/2024 Posts: 4624 Rating:
Following through on your idea but with some helper function.. Attached is a script coded with Siemens' OpennessScripter The script will export code blocks to a folder as XML source.
The attached picture will export all code blocks. The above code will only export one named code block. Regards. |
Activities of this user is voluntary. There is no obligation or liability placed on this user. Though optional, your 'please' and 'thank you' is highly valued. |
3 thankful Users |
