8/5/2020 12:11 PM | |
Joined: 5/9/2020 Last visit: 11/3/2024 Posts: 2 Rating: (0) |
Hello .. Im a beginer here .. I just like to know if and how Im able to install csm 1277 on windows 7 64bits .. Is it ever possible ....? Thanks .... ------------------------------------------------------------------------------------------ |
Last edited by: MMTTMM at: 08/05/2020 12:12:15Last edited by: Jen_Moderator at: 08/05/2020 13:08:27New subject after splitting |
8/5/2020 1:18 PM | |
Joined: 5/12/2006 Last visit: 11/14/2024 Posts: 22452 Rating: (3030)
Hi, what you want to Install? regards christoph |
8/5/2020 1:59 PM | |
Joined: 9/27/2006 Last visit: 11/18/2024 Posts: 12294 Rating: (2691) |
Hello MMTTMM: ChristophD is quite right: there is no software to install on the CSM 1277, so no need for installation under Windows. Look at the CSM 1277 manual, you will find no mention of Windows requirements either in the setup pf the switch or in the installation instructions: S7-1200 Compact Switch Module CSM 1277 https://support.industry.siemens.com/cs/ww/en/view/36087313 Hope this helps, Daniel Chartier |
