11/15/2018 1:23 PM | |
Joined: 4/7/2006 Last visit: 7/31/2024 Posts: 9 Rating:
Hello, i've tried several times to install modbus rtu node to the iot2040 with no success i'm already check the whole forum to get tipps but every time when install it with npm -g install node-red-contrib-modbus i've got this > @serialport/bindings@2.0.2 install /usr/lib/node_modules/node-red-contrib-modbus/node_modules/@serialport/bindings > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild prebuild-install WARN install EACCES: permission denied, access '/home/root/.npm' gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/root/.node-gyp/6.12.3" gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/lib/node_modules/node-red-contrib-modbus/node_modules/@serialport/bindings/.node-gyp" gyp WARN install got an error, rolling back install gyp WARN install got an error, rolling back install gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/lib/node_modules/node-red-contrib-modbus/node_modules/@serialport/bindings/.node-gyp' gyp ERR! stack at Error (native) gyp ERR! System Linux 4.4.105-cip15 gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /usr/lib/node_modules/node-red-contrib-modbus/node_modules/@serialport/bindings gyp ERR! node -v v6.12.3 gyp ERR! node-gyp -v v3.8.0 gyp ERR! not ok > serialport@6.2.2 install /usr/lib/node_modules/node-red-contrib-modbus/node_modules/modbus-serial/node_modules/serialport > prebuild-install || node-gyp rebuild prebuild-install WARN install EACCES: permission denied, access '/home/root/.npm' gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/root/.node-gyp/6.12.3" gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/lib/node_modules/node-red-contrib-modbus/node_modules/modbus-serial/node_modules/serialport/.node-gyp" gyp WARN install got an error, rolling back install gyp WARN install got an error, rolling back install gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/lib/node_modules/node-red-contrib-modbus/node_modules/modbus-serial/node_modules/serialport/.node-gyp' gyp ERR! stack at Error (native) gyp ERR! System Linux 4.4.105-cip15 gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /usr/lib/node_modules/node-red-contrib-modbus/node_modules/modbus-serial/node_modules/serialport gyp ERR! node -v v6.12.3 gyp ERR! node-gyp -v v3.8.0 gyp ERR! not ok any ideas ? Chris ------------------------------------------------------------------------------------------ |
Last edited by: stricky at: 11/15/2018 2:11:34 PMLast edited by: Jen_Moderator at: 11/15/2018 2:52:05 PMNew subject after splitting |
9/11/2019 1:20 AM | |
Joined: 2/10/2017 Last visit: 10/10/2023 Posts: 53 Rating:
Thanks, it works with image V2.4 !!! |
