8/25/2020 6:39 AM | |
Joined: 11/25/2017 Last visit: 3/15/2024 Posts: 24 Rating: (0) |
Hi Abdel-Qader, I am in a similar situation. Did you have any solution on how to transfer in IEC 61850 system. I have bought SIcam A8000 CP -8022 instead of S7-1200. But do not know the procedure of integration it with Wincc/Scc. If you have any idea or knowledge , share me. Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/25/2020 10:24:17New subject after splitting |
8/25/2020 3:52 PM | |
Joined: 10/10/2014 Last visit: 6/26/2024 Posts: 1725 Rating: (210) |
Hi Aiyub, If you use SCAM SCC there is a channel for the communication SICAM PAS Protocol Suite If you like to use OPC for the communication add the OPC channel. WinCC is OPC client. Best regards |
8/26/2020 11:09 AM | |
Hi Aiyub,
Try to searc .sxd in the manual Best regards |
