10/14/2019 8:04 AM | |
Joined: 4/28/2015 Last visit: 9/9/2024 Posts: 3345 Rating: (379)
Hi, there is no real manual how to get connected to a third party PLC using RS232. But there are some examples in the forum for RS232 communication. For example you could use node-red for that (https://support.industry.siemens.com/tf/ww/en/posts/181907) By using the search function you will find more threads regarding Modbus / RS232. You also can use "normal" TCP/IP or OPC UA communication with PLCs to communicate via Ethernet. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
