4/25/2023 12:06 PM | |
Joined: 8/24/2022 Last visit: 5/7/2024 Posts: 5 Rating: (0) |
When trying to compile code #1, it gives a critical error. Code #2 fixed that problem. Is this a compiler problem ? code #1 fail
code #2 work
code#3 work
P.S. I think the problem is in the compiler and in the assembly sequence of the instructions. But the developer knows better. This bug is also present in TIA version 18 I share TIA DIAG file [snip] AttachmentFiles.zip (171 Downloads) |
Last edited by: m0t0r0v at: 04/25/2023 12:21:19Last edited by: m0t0r0v at: 04/25/2023 12:27:28Last edited by: m0t0r0v at: 04/25/2023 12:52:23Last edited by: m0t0r0v at: 04/25/2023 12:52:56Last edited by: m0t0r0v at: 04/25/2023 12:53:27Last edited by: m0t0r0v at: 04/25/2023 12:53:43Last edited by: m0t0r0v at: 04/25/2023 13:17:09Last edited by: Jen_Moderator at: 04/26/2023 07:23:06Link removed and all files added as .zip file. |
4/25/2023 2:13 PM | |
Joined: 1/21/2013 Last visit: 5/20/2024 Posts: 2798 Rating: (452) |
Hi m0t0r0v, Thank you for sharing your experience with us. However, if your intention is to report a bug, you should create a support request. Kind regards |
4/26/2023 6:31 AM | |
Of course, I described the bug for support, but you know that SIEMENS support works slowly and works only after a mug of beer and sausage. >:] P.S. The last part of the message did not want to offend anyone. Just a long experience with support. |
