7/8/2015 11:02 AM | |
Posts: 14 Rating:
Dear all, With PG but don't have programming cables. How to make programming cable for step 7 and step 5?
Thakyou
Regards
Last edited by: Min_Moderator at: 7/8/2015 1:32:03 PMNew subject after splitting |
7/8/2015 2:40 PM | |
Joined: 9/27/2006 Last visit: 7/23/2024 Posts: 12270 Rating:
Hello ukybasuki; If you download the Operating Instructions for your model pf PG, you will find information on the cables originally provided with thwe PG; along with the part numbers for the purchasable cables for S5 and S7, you will find wiring diagrams for cables that you can build yourself (such as the 6ES5734-2BD20 to connect to a S5 AS511 programming port). Note that this cable includes TTY/serial conversion circuits. The attached extract was taken from the Operating instructions for the PG M4: Search for your model pf PG using the Search box at the top of this page, then filter on Manuals.
SIMATIC Programming device SIMATIC Field PG M4 Hope this helps, Daniel Chartier |
7/13/2015 4:25 AM | |
Posts: 14 Rating:
Dear all, Thankyou for all of you, for your advise... Regards Basuki |
