7/18/2023 3:56 PM | |
Joined: 12/20/2022 Last visit: 6/12/2024 Posts: 2 Rating:
Hi, were you able to make the PXC001.E-D working as Modbus TCP slave? The release note is not clear how to configure it Thank you Michele ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 07/19/2023 07:48:08New subject after splitting |
7/19/2023 7:53 AM | |
Joined: 7/25/2012 Last visit: 8/6/2024 Posts: 266 Rating:
Dear Michele, if you have the documentation collection from your local support, then you can find a document "CA2Y9772en_06.pdf", where is described details about configuration in XWP tool for PXC001. If you don't have it, you can download the document from SID: https://sid.siemens.com/v/u/A6V10690151 Hopefully, it will helps to you.
Best regards, |
7/19/2023 1:27 PM | |
Hi Jan, thanks for your reply. I already have the document you posted, but there is no trace about Modbus TCP communication. Anyway the in document _Release_Notes_PX_Modbus_FW_PXC001...D_V6.00.327_EN.doc seems to be possibile to have a PXC001.E-D as a Modbus TCP Slave but is not clear enough how to define it. Do you have some idea? Firmware downloaded: FW_PX_Modbus_PXC001...D_V6.30.024.dwz Modbus configuration attached. Thanks again AttachmentSlave screenshots.docx (313 Downloads) |
