3/21/2024 12:40 PM | |
Joined: 3/21/2024 Last visit: 3/21/2024 Posts: 1 Rating: (0) |
Hi, I have backup of soft starter project file with an extention of *.zap19 ,How ever I could not open the file with TIA Portal V18 . Is there any way to open *.zap19 files with TIA Portal V18 . Thank you ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 03/21/2024 14:21:51New subject after splitting |
3/21/2024 6:34 PM | |
Joined: 7/7/2010 Last visit: 11/6/2024 Posts: 15385 Rating: (2443)
[Please forgive my attempt at helping you and trying to be funny....] Yes, you can. Launch TIA Portal V18, and then forget you opened it. Now launch TIA Portal V19 (install it if it is not already installed, and install the latest V19 update). Open the project in the most recently launched TIA Portal - but in the back of your mind you know you started this process by starting up V18... With the zap19 (v19) project open, you can use a dual monitor setup and manually recreate in V18 whatever you see in that open project on the other screen in that other portal software. If you need PLC tags, UDTs, SCL, DBs, you can export those to text files and make them importable in V18.
science guy |
