6/14/2018 4:33 PM | |
Posts: 1 Rating: (0) |
Dear Sir, I have a system with PLC Simatic S7 -400 CPU 412-5H PN/DP . I just change the bateires for the slave PLC andi get some fault .EXTF light red and REDF light red . I want to ask how to perform a reset for this alarm . I have no any posibilyty to use a laptop . Thanks ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 6/15/2018 1:22:51 PMNew subject after splitting |
6/22/2018 4:26 PM | |
Joined: 11/29/2011 Last visit: 6/6/2024 Posts: 1358 Rating: (232) |
Hi, The diagnostic buffer will tell you exactly what is causing the LED lit up. If you upload it, we can have look at it. Anyways potentionally the battery issue caused the EXTF LED to lit up. You will see the relevant diag buffer entries relate to OB81 (Power Supply Error OB). About battery replacement procedure see SIMATIC S7-400 S7-400 Automation System Module Data |
- What you read here, please check with manuals and your requirements. |
