6/17/2013 2:39 PM | |
Posts: 3037 Rating:
Hello, How do you start a sound file via a script in the WinCC flexible PC Runtime? Tweety |
6/18/2013 12:40 PM | |
Posts: 27 Rating:
This example uses bit alarms (alarms defined on WinCC Flexible). I need a method to detect a new (unacknowledged) CPU generated alarm (ALARM_D function). |
6/18/2013 5:10 PM | |
Posts: 3037 Rating:
hello, If you display the systemmessages in your messageview also. Does a systemessage if you trigger an alarm_D message? Tweety |
7/10/2013 12:11 PM | |
Posts: 515 Rating:
Hi memet, i dont think there is an internal function available for this purpose. i used to do the codings in the PLC logic rather.
