1/22/2018 3:56 PM | |
Posts: 6 Rating: (1) |
hi, im trying to reference Z axis on a 5axis machine that we removed the Z axis column. the Z axis has a heidnmann distance coded linear scale , ive tried alot of different parameters ,when ever i press Ref after changing the parameters and adding that value position , the z axis only moves 20 mm in either direction im pressing if i press the ref - then + it will move + direction for bout 20mm then say its referenced. but i press it again and it does same thing changing the reference all the time, even if i press "-" it will move "-" and reference there aswell. any ideas ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 1/23/2018 9:11:39 AMNew subject after splitting |
1/23/2018 9:12 AM | |
Joined: 6/19/2017 Last visit: 5/17/2024 Posts: 8044 Rating: (164) |
Closed cause question posted twice.
