2/4/2024 7:01 AM | |
Joined: 6/27/2023 Last visit: 5/31/2024 Posts: 1 Rating: (0) |
Hello, I have a HMI that before me, another person programmed it. Now i want to upload or reset factory it but non of them i can't. because when i turn off hmi and again turn it on, in hmi i can't select transfer or settings menu and just start menu appeared. i try to get back up by prosave software but couldn't because prosave can't connect to hmi so again try to reset factory by usb in accordance with https://support.industry.siemens.com/cs/af/en/view/109744950 and again i couldn't. what can i do? i want to have back up of this program or write a new program to it but none of them i can't? |
2/4/2024 8:04 PM | |
Joined: 12/16/2021 Last visit: 5/5/2024 Posts: 7 Rating: (1) |
Hi AutoGen, It sounds like you may have already tried it, but can you connect via TIA and reset to factory that way? On the right hand menu, properties of the HMI > HMI Device maintenance > Reset to factory settings. I've attached a screenshot of the next window that appears, i've just tested it with my KTP 700 Basic. Good luck! |
