1/17/2022 11:51 AM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8176 Rating:
Hi Arnulfo Munoz, Please try to discuss your question in English language. This is an international community and we try to focus on one language. Posting in English will help you to get more response to your question. This is the translation of your question:
Regards, |
1/17/2022 11:04 PM | |
Joined: 7/2/2021 Last visit: 4/4/2022 Posts: 24 Rating:
THANKS FOR YOUR QUICK RESPONSE. ATTACHED IMAGES ABOUT THE EQUIPMENT CONTROL, SINUMERIK 810D CPU810DE CCU1 SOFTWARE VERS. 2.4 SINUMERIK 840D, BS002 MMC 103: 133MHZ Attachmentdatos maquina.zip (443 Downloads) |
Last edited by: Jen_Moderator at: 01/18/2022 08:49:46Edited text for better reading. |
1/17/2022 11:10 PM | |
I ALSO ATTACH THE ERROR MESSAGES THAT APPEAR WHEN TRYING TO ACCESS THE PLC STATUS PAGE. ALSO ERROR MESSAGES WHEN TRYING TO PERFORM NC and PLC RELOAD PROCEDURE
Attachmentalarmas.zip (459 Downloads) |
Last edited by: Jen_Moderator at: 01/18/2022 08:50:29Edited text for better reading. |
1/17/2022 11:19 PM | |
FINALLY ATTACHED THE PROCEDURE TO LOAD NC FILES. ARC and PLC.ARC WHICH GIVES ME ERROR "INALLOWABLE DATA TYPES IN DESTINATION DIRECTORY" WHEN TRYING TO LOAD NC FILE. ARC, AND FOR PLC.ARC INDICATES THAT THE FEHLER FILE DOES NOT EXIST. THE PROCEDURE USING WINPCIN I HAVE NOT BEEN ABLE TO USE BECAUSE I HAVE NOT BEEN ABLE TO FIND HOW TO DOWNLOAD THAT SOFTWARE. I ALSO READ IN THIS FORUM THAT IF THE UNIT HAS MMC103 IT WAS NOT NECESSARY TO CONNECT THROUGH AN EXTERNAL PG or PC. SOMETHING I WANT TO COMMENT IS THAT THE MEMORY LOST THE INFORMATION WHEN TRYING TO MOVE THE ROTARY SWITCH S3 TO POSITION 1, IF WE TYPED THE PARAMETERS MANUALLY (AS THEY ARE ERASED) WE ACHIEVED THE RED SF LED ON THE NCK TO TURN OFF BUT THE UNIT STILL NO ANSWER Attachmentprocedimiento.zip (361 Downloads) |
Last edited by: Jen_Moderator at: 01/18/2022 08:51:07Edited text for better reading. |
1/17/2022 11:21 PM | |
CNC EQUIPMENT MANUFACTURER HYUNDAI MODEL HIT-8 |
1/19/2022 7:15 PM | |
ANY COMMENTS TO SOLVE THIS PROBLEM IN MY CNC EQUIPMENT |
