3/2/2022 2:36 PM | |
Joined: 4/6/2021 Last visit: 3/3/2022 Posts: 1 Rating:
h have siemens relay 7sj661 with UV/OV voltage due to wrongly set the values it block and give trip and stack I can't reset it or edit the setting. my question how i return the relay to factory reset ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/03/2022 08:52:43New subject after splitting |
3/3/2022 12:33 PM | |
Joined: 8/12/2021 Last visit: 6/26/2024 Posts: 314 Rating:
Hi YR64, You may be able to find the answer here: Manual SIPROTEC 4 7SJ66 Multi-Functional Protective Relay with Local Control |
