7/2/2024 11:52 AM | |
Joined: 7/27/2023 Last visit: 7/29/2024 Posts: 60 Rating:
Hi! You can create a FB with inputs and outputs and insert in it your code. This way you can instantiate it several times: - Function blocks (FB): https://support.industry.siemens.com/cs/es/en/view/109815056/71131474955 This FB can be saved as a library so you can export it to different projects. |
Last edited by: The Helping Hand at: 07/03/2024 13:20:31Link and text formatting optimized |
7/2/2024 1:40 PM | |
Joined: 11/21/2020 Last visit: 8/5/2024 Posts: 115 Rating:
Thanks, I'll check it. What a boring BS is screen building. |
7/2/2024 1:50 PM | |
Aaaaamhhhh, that is the reason. OK, I'll try it. |
