11/1/2017 9:06 AM | |
Posts: 37 Rating: (0) |
Hello, I encountered a problem with a tia port ver 13 project. My problem is to send a series of code to a sensor that contains 16 # 55.16 # 81.16 # 81.16 # 5 c, # 16 # 03. The sensor structure is such that all the codes must be sent together and I do not know how to send them. Meanwhile, I used cb1241 for this, which also supports the rs485 sensor. To send the codes, use send-ptp. M. Please tell me how to do this ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/3/2017 6:09:54 AMNew subject after splitting |
11/1/2017 7:32 PM | |
Attachmentmicrometer_std_protocol_3.pdf (169 Downloads) |
11/1/2017 7:35 PM | |
I sent you the code for the code. Please see and say how the codes will be sent. The codes for each function should be sent together. |
11/2/2017 10:21 AM | |
Hi, I'm having trouble choosing a communication protocol. My problem is how should I send the codes to 323 bit larger than the sensor? I will send sample code for you
Attachmentmicrometer_std_protocol_3 (1).pdf (134 Downloads) |
11/2/2017 10:44 AM | |
Hi, I can connect to a non-Siemens sensor. Can I use ptp? |
