4/5/2012 7:11 AM | |
Joined: 8/31/2010 Last visit: 7/26/2024 Posts: 1519 Rating:
Hello Tom, [schnippschnapp] KTP 600 Basic is not a Windows CE based panel, so you can read time from PLC and display the same in your KTP 600. In S7-1200 you can make use of these instructions - Set and read system clock in S7-1200. Create an I/O Field in your Panel and then Choose the Layout as "Date/time' and then choose your DTL tag from PLC and link it in the Process Tag (I/O Field) |
12/3/2014 1:06 PM | |
Joined: 7/28/2009 Last visit: 5/10/2022 Posts: 90 Rating:
HI I can follow the procedures for date and time in KTP 600. But do I get the same in Alarms also. |
Cheers |
12/15/2014 5:32 AM | |
Hello Revathy, Raise aSupport Requestand the technical support team should help you out.
Like it? Rate it! |
