12/2/2022 7:15 PM | |
Joined: 1/24/2021 Last visit: 12/27/2024 Posts: 196 Rating:
First of all plug network cable in your PCU, also plug in PS/2 mouse (it is not necessary, but will help you with navigation). Power on your machine. After BIOS start up screen there will be another with system loading meny. Will this screen appears press <F8> (right softkey). You will enter service menu. PLEASE SELECT 1 Install/Update SINUMERIK System 2 SINUMERIK Tools and Options 3 DOS Shell 4 Start Windows (Service Mode) 5 SINUMERIK System Check 7 Backup/Restore 8 Start PC Link 9 Reboot (warm boot) Your Choice [1, 2, 3, 4, 5, 7, 8, 9]? You should choose [4] Next menu appears : PLEASE SELECT 1 Standard Windows (without starting SINUMERIK HMI) 4 Original SINUMERIK HMI environment 5 Current SINUMERIK HMI environment 9 Return to Main Menu Your Choice [1, 4, 5, 9]? Press key [4] The system prompts you to enter a password, use "SUNRISE" (all symbols are capital). The symbols will no appear while you typing. Also use <SHIFT> because by default in service menu low register is activated. You will start Windows without starting HMI. After system have been loaded use instructions from attached document to setup IP address for your PCU. Take care that choosed IP is free and subnet mask is the same with subnet mask used in your local network. Try to ping your PCU from another computer in your network. If connection is established then you should share folder on your PCU. Open folder F:\840System\dh (I will check actual path on monday). Choose there folder "clip.clp" and set access rights for it. Use instruction from link, also it is described how to find shared folder on other computers. https://www.eduhk.hk/ocio/content/faq-how-share-files-windows-xp-access-control-list-acl Attachmentsetting IP for PCU.pdf (580 Downloads) |
People are divided into those who do Backup and those who will do it. |
12/2/2022 7:23 PM | |
Concerning your second question read attached manual. Answer your are looking for is on page 363. Regards, Snik AttachmentManaging data HMI Advenced.pdf (538 Downloads) |
12/6/2022 12:23 PM | |
Joined: 3/24/2021 Last visit: 12/7/2022 Posts: 3 Rating:
one more time, thanks so much Snik!! best regards! Elias |
