10/6/2023 11:57 AM | |
Joined: 4/28/2015 Last visit: 7/4/2024 Posts: 8 Rating: (0) |
Hi. So I can use parameter set Id to read the loaded parameter set name? Should it have an @ before the tag? Regards /Uffe |
10/10/2023 5:19 AM | |
Hej. Tack, jag testar igen. Hälsningar /Uffe |
10/10/2023 7:49 AM | |
Joined: 12/23/2021 Last visit: 2/21/2024 Posts: 234 Rating: (23) |
Hi! Did you see the Unified manual that is attached in the first link that we shared you? In this section you could get interesting information to solve your issue: Managing parameter sets |
If this post helped you in any way, please rate it positively. |
