4/17/2017 6:55 PM | |
Joined: 6/2/2009 Last visit: 9/25/2024 Posts: 61 Rating: (3) |
Hi all, I'm searching hard how to use a variable (exp.variantPTR) able to contain pointers. I have to use T_SEND but I need the DATA input to represent sometimes P#DB10.DBX0.0 BYTE 4, sometimes P#DB11.DBX0.0 BYTE 6, ... to be able to send different DataBlocks of different Types and Structures. Here is my following example but it is INCORRECT, How to write it correctly? IF #iSelect>1 THEN REQ:=false, ); Thank you for help, I find no solution and deadline is close... David ------------------------------------------------------------------------------------------ |
Last edited by: David4444 at: 4/17/2017 7:01:41 PMLast edited by: Min_Moderator at: 4/18/2017 12:13:10 PMNew subject after splitting |
4/17/2017 10:50 PM | |
Thank you very much for your quick answer, Dan, I will apply it ASAP, Thank you again, David |
