4/19/2016 7:16 PM |
Joined: 7/19/2011 Last visit: 6/20/2024 Posts: 262 Rating: (5) |
Pls tell whether you are using a HMI or scada. |
JAVED AKHTAR |
5/9/2016 7:45 AM | |
Posts: 144 Rating: (7) |
Hi you can use "tag prefix" property of picture window. How do you use the Tag Prefix property?How do you use screen windows and tag prefixes with WinCC RT Professional (TIA Portal)? |
5/12/2016 9:14 PM | |
Posts: 439 Rating: (108) |
Hello, You can have a maximum of one pop-up open at a time for WinCC Comfort / Advanced V13 SP1. It is the same thing for WinCC Professional V13 SP1 as well. As said by others, you should use faceplate. I joined a pdf document that explain how to create faceplates to the post. Best regards, Hugo AttachmentFaceplate et UDT HMI_EN.pdf (1312 Downloads) |
