4/16/2021 3:40 PM | |
Joined: 4/24/2006 Last visit: 5/7/2024 Posts: 8634 Rating: (1149) |
Hello, It is not possible to use TP177B in TIA v16 Best regards, Wizard |
4/21/2021 3:57 PM | |
Joined: 8/3/2009 Last visit: 5/6/2024 Posts: 12884 Rating: (1645)
Hello https://support.industry.siemens.com/cs/de/en/view/109753803 " The following HMI devices are no longer supported as of TIA Portal V15:
" Bye Murof |
9/22/2021 7:43 AM | |
Joined: 9/16/2013 Last visit: 1/27/2022 Posts: 17 Rating: (1) |
Thanks for the info. Is there any solution still to add it to a project in TIA portal like device proxy or whatever? Thank you
