2/1/2023 10:15 AM | |
Joined: 7/19/2022 Last visit: 8/12/2024 Posts: 380 Rating:
Hi jofi, I suggest to create a function call at the runtime start which opens the Windows commandline in the background. And there you could perform the start of your batch-file. |
8/10/2023 7:44 PM | |
Joined: 10/25/2021 Last visit: 7/2/2024 Posts: 14 Rating:
Hello, I followed the following instructions and I was able to run a .bat without any problem. I hope it works for you :) Greetings! https://support.industry.siemens.com/cs/es/es/view/109798677 |
