6/26/2010 12:32 PM | |
Joined: 9/28/2005 Last visit: 7/10/2024 Posts: 2957 Rating:
Hello, Go to device configuration, enable desired HSC and in "Events" tab assign it to hardware interrupt. Interrupt will be generated when count value is equal to reference. For more info refer to S7-1200 System Manual section 6.1.3.4. |
Best regards, |
6/18/2014 11:00 AM | |
Posts: 1 Rating:
HI ched, I have the same problem, can you explain how you solved your problem? |
3/14/2017 4:09 PM | |
Posts: 5 Rating:
Hi, I see this post is been in stand-by for some time. I'd like to know if you could solve it because I am needing to use a HSC. Thanks ;-) |
