8/18/2017 2:29 PM | |
Posts: 7 Rating: (2) |
Hello All, did you found solution to this problem ? I am using TIA Portal v14 (all updates installed using the official updater) - not able to browse accessible nodes but once I have the address I can connect without problem. I am running on Win7 64bit with SEP Version 14 (14.0 MP1) build 2332 (14.0.2332.0100). I have contacted our IT department to help with the issue, they want to know what they should put in the exception list, which device, process, open some port ?
Regards, Goce ------------------------------------------------------------------------------------------ |
Last edited by: DimitG at: 8/18/2017 2:30:32 PMLast edited by: The Helping Hand at: 8/21/2017 9:29:29 AMNew subject after splitting |
