7/4/2011 10:35 AM | |
Joined: 6/17/2010 Last visit: 1/1/2024 Posts: 31 Rating: (0) |
hi friends i am using s7400h system(412H) in my project how can i find battery fault in powersupply thanks aravind Splitted from S7 400 Backup Battery. |
7/4/2011 11:56 AM | |
Joined: 4/24/2006 Last visit: 10/18/2024 Posts: 8746 Rating: (1169) |
Hello, You should use OB81. It is called when battery fault. See the following links: What is the effect of the 1 Batt./OFF/2 Batt. settings on the BATT.INDIC switch? Why is a battery fault signaled when you insert a back up battery, even though the battery is new? /tf/WW/en/Posts/54304 Best regards, Wizard |
