3/14/2011 7:46 PM | |
Posts: 8 Rating:
CP3431_CX10BACnet_V1_1_44l_V1_0_021_001_rel.zip Hi there, İ cannot download this file, anybody can check that. Splitted from BAC net -> profibus ?. |
3/15/2011 11:13 AM | |
Joined: 4/24/2009 Last visit: 2/19/2024 Posts: 2682 Rating:
Hello bbir, did you try to download it from the following site? http://support.automation.siemens.com/WW/view/en/41173255 Which browser do you use? Can you show us a screenshot what happens when you try to download? Best regards O_Moderator |
3/15/2011 11:57 AM | |
Posts: 8 Rating:
Hi, I use m.firefox. Other file download is ok, the above files. I attached the screenshot, there is a messsage : ....siemens server couldnt find. Thank you , |
3/15/2011 1:20 PM | |
Posts: 8 Rating:
Hello O_Moderator I tried IE but, its same result.. Thanks. |
3/15/2011 1:36 PM | |
I will check this. For now i upload the file(in two parts, because the hole file is to big) here Best regards O_Moderator AttachmentCP3431_CX10BACnet_V1.1.44l_V1.0.021.001_rel.zip (251 Downloads) |
part2
AttachmentCP3431_CX10BACnet_V1.1.44l_V1.0.021.001_rel_2.zip (250 Downloads) |
3/15/2011 4:26 PM | |
Posts: 8 Rating:
OK.. Thanks. |
