8/5/2015 8:26 PM | |
Posts: 4 Rating: (0) |
Hi, I am using WIn CC Professional v13 UPd1 but I cant use the PLC UDT in my faceplate. I doest appear
Last edited by: Min_Moderator at: 8/6/2015 11:05:49 AMNew subject after splitting |
8/5/2015 8:53 PM | |
Hi, i have winnc professional v13 and a s7-1200 plc I did the procedure but I cannot use the type PLC data type that if added to the project library.... |
10/12/2015 3:27 PM | |
Posts: 22 Rating: (0) |
Hi Have you copy the UDT file into the project library and called it in the Faceplate? thanks |
10/13/2015 7:49 PM | |
Joined: 9/23/2005 Last visit: 4/29/2024 Posts: 4325 Rating: (1424)
Hi,
did you tried to update to V13 SP1 upd5? |
Denilson Pegaia |
12/20/2016 3:58 PM | |
Joined: 8/3/2009 Last visit: 4/30/2024 Posts: 12869 Rating: (1642)
Hello everybody look in this FAQ everything is explained: https://support.industry.siemens.com/cs/ww/en/view/68014632 Bye Murof |
