11/25/2011 4:30 PM | |
Joined: 1/28/2009 Last visit: 7/11/2024 Posts: 6842 Rating:
Dear kaspergl, Please check the following thread for more information: FB58 & FB59
Best regards, Hamid Hosseini |
11/25/2011 4:44 PM | |
Posts: 5225 Rating:
kaspergl, I am sorry for not knowing you do not know PLC programming langauges all that well. Siemens has many PLC language platforms you can use. This forum would be happy to give you an introduction to this if you require it. The good news is that "SCL" is like Pascal and will suit you well.. Pascal is also not too far a leap from C. Knowing the software and language is key.. If I ask you to develop code for an embeded system using JavaME you will study it in-and-out, before you start. I realise however that this does not resolve your issues. Please let us know: - what the problem is - what your frame of reference is, - what you know to solve the problem - what tools you are using (software & hardware) - what type of help you require from us As example.. I have Step7 V5.1 which is an old software version and my "help" might just agrivate your frustration. We will need to know which software (Step7) you are running to explain how and where you can set a timed interrupt. Someone can give you a step by step, if you ask for it. over and out. |
