11/21/2007 8:39 PM | |
Posts: 1 Rating:
Please help me for findgsd file for c7-634dp |
11/22/2007 9:52 AM | |
Joined: 9/27/2006 Last visit: 8/5/2024 Posts: 12273 Rating:
Hello azalsadeh1; The C7-634-DP incorporates a S7 CPu and an OP in one panel: "The C7-634 P and C7-634 DP control systems have a SIMATIC S7-300 CPU 315 or CPU 315-2 DP as the C7 CPU and an OP 17 as the C7 OP." (from the C7-63x System manual).You should be able to use the gsd file for the CPU 315-2DP for your application (you are trying to integrate the C7-634-DP as a slave on a Profibus-DP network, no?). You can find the gsd file for the S7 315-2DP here: http://support.automation.siemens.com/WW/view/en/113652 Hope this helps, Daniel Chartier |
