6/15/2022 6:50 AM | |
Joined: 10/8/2018 Last visit: 8/7/2024 Posts: 14 Rating: (0) |
I want to learn VBS and C script in Wincc but I do not understand the manual well can you help me ------------------------------------------------------------------------------------------ |
6/15/2022 4:27 PM | |
Joined: 8/12/2021 Last visit: 11/14/2024 Posts: 332 Rating: (31) |
Hi ghasema2010! I'm not sure what topic was being discussed, but if you have problems with scripting, these FAQs may help you: Which VBS information and VBS programming tools are there in WinCC (TIA Portal)? |
6/24/2022 2:30 PM | |
Joined: 8/3/2009 Last visit: 11/18/2024 Posts: 14181 Rating: (1774)
Hello first we need to know which Version of WinCC you use? You are in the WInCC flexible Conference so in WinCC flexible you can only use VBS and here are some information:
If you have another Version of WinCC then we need the Information first and then we can give you the proper answer. Bye Murof |
