7/12/2010 6:49 AM | |
Posts: 2964 Rating: (482) |
Hello... I have a question when ever your replacing the I/R module there is something called dip switch settings in it. Have you checked it out? When your replacing with new one module you need check the older module dip switch setting note down the same and do it on the what module you are going to replace.... If switch no 1.6->OFF-Square wave current and 1.6->ON Sinusoidal current.... if this is not taken care propelry chances are there for the failure.... for reference i am attaching the document... Check it out.. Ekalavya Attachment611A switch settings.pdf (327 Downloads) |
7/12/2010 2:02 PM | |
Posts: 22 Rating: (1) |
Hello, The dip switch seting is same for all three module. The two module who burnt are new from Siemens,in guarantee.. Iri |
