6/7/2010 8:51 PM | |
Joined: 10/7/2005 Last visit: 10/20/2024 Posts: 3024 Rating: (1054)
Hello manju@vaes please check if "Test, commissioning and routing" is enabled for the DP Slave port (gut feeling tells me its not whichmeans that online access is still possible, but will be sloooow). Please also check if the setting for"Test mode" is made for the CPU (this allows a greater increase in cycle time for the CPU tohelp with online communciation). Have a look at the attached pic which shows you where to find these settings and let us know if it improved online update times (I hope so, because I can't think of anything else). I hope this helps |
Cheers |
11/17/2020 10:47 AM | |
Joined: 2/4/2018 Last visit: 10/17/2024 Posts: 57 Rating: (0) |
Hello experts, I have a similar problem, any ideas? thx KD
