12/4/2007 3:28 PM | |
Joined: 4/24/2006 Last visit: 7/12/2024 Posts: 8711 Rating:
Hi, Hot swapping: You can pull out an I/O card, without interrupting the I/O bus, so all other cards will function (if CPU supports HotSwapping When you use normal rack: you can pull out I/O card, but all cards on the right will loose communication with IM, because I/O bus is interrupted. Here is a link to manual ET200M: http://support.automation.siemens.com/WW/view/en/1142798 Best regards, Wizard |
