11/10/2009 7:55 AM | |
Posts: 37 Rating:
Hi All,
I am facing a problem with configuring the IM 153-2 with S7 315 that I cannot compile the IM153 in the hardware configuration and gives the error number: (1230:3000). At the same time I was testing this IM153-2 with other project (S7 313) that was fine and no error!! You can see the hardwire configuration for both project attached. So I do not know?? is there a compatibility issue or I need to do a further step!Any help would be appreciated. PLC Product #: 6ES7315-2EH13-0AB0. IM153 Product#:6ES7153-2BA02-0XB0 Thanks Mans AttachmentIM153-2.zip (199 Downloads) |
Last edited by: MANS at: 11/10/2009 9:45 AMLast edited by: MANS at: 11/10/2009 9:44 AM |
11/10/2009 12:20 PM | |
Joined: 8/25/2005 Last visit: 7/5/2024 Posts: 1162 Rating:
Hello MANS, could you please publish the information given behind the button Details Best regards Sabine |
11/10/2009 4:27 PM | |
Joined: 5/28/2008 Last visit: 7/12/2024 Posts: 4511 Rating:
Dear MANS, I have did the HW config as per your attached pictures without errors in compilation. Really I do not know what's the reason of this error in your configuration. In any case, here's attached an archive of the project I have made for you. Open HW config and check it. Regards, Attachment315_2pn_.zip (230 Downloads) |
Ayman Elotaify |
11/11/2009 8:50 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating:
Hello Mans, Glad to hear you already solved problem.
If we take this like starting point and look at Consistency error after configuration of the CPU as time slaveperhaps this could be real reasons for your "troubles". With regards, Hristo Mihalev |
